Are you using a reflected ceiling plan view or a floor plan view? Using an RCP view will make everything show up in reverse order, because you're looking up at the ceiling, so lights will appear to be above ducts. Also what is your cut plane set at? I've had the most success setting my top range to the floor above, and the cut plane somewhere above the highest mechanical equipment.
