Revit MEP Forum
Displaying an electrical equipment's circuit number
1 REPLY 1
ArynBergman
1239 Views, 1 Reply
In Electrical Fixtures, there is a property called Electrical Circuit that is the circuit that’s it’s attached to.  I need to get to that same info for electrical equipment that’s also are a part of an electrical circuit but not the panel for it.  For example I’ll have 5 RPP’s attached to an SB and I need to show the circuit numbers for the RPP’s in their tags.  Is there a way to do that or is there a way to create a schedule that will show the circuits that the RPP's are associated with?
1 REPLY 1
CoreyDaun
in reply to: ArynBergman
Yes, that parameter is not available in an Electrical Equipment Schedule. I haven't investigated, but the best you could probably do is to create an Electrical Circuit Schedule with an Embedded Equipment Schedule. This is just a guess as I haven't the time at the moment to confirm this.
