Revit MEP
Valued Contributor
Message 1 of 6 (303 Views)
Display of pipes beyond
303 Views, 5 Replies
07-12-2013 09:18 AM
I am in Revit MEP 2013
I am on the second floor of a multi story building.. There is a shaft opening were I can see the pipes on the first floor. I would like these pipes to display single line but even when I am in Detail Level: Medium they show up Double line.. How can I change this.
CADastrophe
Message 2 of 6 (230 Views)
Re: Display of pipes beyond
07-16-2013 07:08 AM in reply to: pverduzco
Hello pverduzco,
I've not been successful in reproducing this scenario. Would you be able to mock this up in a New Project and post that file here? In order to get the file small enough to post here, you'll have to use the Purge Unused a few times and then manually remove all of the unused Pipe and Duct Fitting Families from the Project Browser.
Sorry for the delay of response.
Valued Contributor
Message 3 of 6 (225 Views)
07-16-2013 07:13 AM in reply to: CADastrophe
Thanks for your response.
This is a 6 flr building so It might take me a while but I will try and do the process you mentioned and upload it.
thanks
Active Contributor
Message 4 of 6 (205 Views)
07-17-2013 05:14 AM in reply to: pverduzco
Check the view's Underlay parameter. Looks like it may be set to First Floor. Change it to <none> and then go from there.
Valued Contributor
Message 5 of 6 (179 Views)
07-18-2013 12:49 PM in reply to: jkarben
I am guessing you are in a view that was duplicated. When you duplicate a view, Revit will automatically add an underlay. Just clear the check, and it should be fine.
genem@... (NNTP handle: genemarz)
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 10 years
as genemarz
Valued Contributor
Message 6 of 6 (171 Views)
07-18-2013 01:18 PM in reply to: jkarben
Thank you all Revit Peeps
The underlay was set to Level 1.. now set to none.. problem solved..
Thanks again..
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
