Is there any process to delete duplicate entity in Revit. The entity may be pipe or duct or any annotation text etc.
Thanks in advance!
Thansk for your response.
If we copy the same entity in the same place then it will be not purge because it is used in the project. My question is how we delete the duplicate second entity.
In this case all the element will be deleted but we delete the duplicate elements.
For a example:
So please suggest.
We can't create any duplicate object from the type DB. Mainly we have placed the same element in same location.
For a example Pipe 6" have placed in same place in two times. Noe we delete one of the entity. In AutoCAD there is a command (overkill) which delele the duplicate element in same place.
There is no great way to address multiple instances at once, but you can locate the offending elements by going to Warning (on the Manage tab) and looking for the "There are identical instances in the same place..." messages. From the Warnings dialog, you can expand the message, select one of the listed items, and click "Delete Checked..." to remove one of them.
When we copy Pipe & Duct entity with fittings in same location we can't delete the pipe & duct where as we delete only fittings. We have attched a snap for your easy reference.
OK. Yeah, you're right, sorry. In that case, try using the Interference Report between Ducts and Ducts only, and then Pipes and Pipes only. This will help you find the locations of duplicate instances. after deleting and instance, you can go to Interference Check > Show Last Report to bring it back up quickly. There is no good way to go about this. How did so many duplicate instances get created?
