Revit MEP
Active Contributor
zingero84
Message 1 of 10 (906 Views)
Custom Construction Type R and U values
906 Views, 9 Replies
04-13-2012 09:32 AM
How do we create custom construction types to specify u and r values?  This is driving my nuts.  I have to find a number that's "close" but this isnt working out the best.
Ideas?
CADastrophe
Message 2 of 10 (904 Views)
Re: Custom Construction Type R and U values
04-13-2012 09:40 AM in reply to: zingero84
Find the file "Constructions.xml" within the directory "...\Program Files\Autodesk\Revit MEP 2012\Program\" assuming, of course, you're using RMEP 2012. Open the file in a program that can read it, such as Microsoft Excel, and then you should be able to add to, edit, and change these values as you see fit.
Active Contributor
zingero84
Message 3 of 10 (899 Views)
04-13-2012 09:54 AM in reply to: zingero84
I get the error, "Cannot save or export XML data.  The XML maps in this workbook are not exportable."
So what's next?
CADastrophe
Message 4 of 10 (893 Views)
04-13-2012 10:12 AM in reply to: zingero84
I opened it in Microsoft Excel 2007 and then did SaveAs, setting the "Save as type" to "XML Spreadsheet 2003 (*.xml)". That got around the error. Be sure to save a backup of the original .xml file JIC.
Active Contributor
zingero84
Message 5 of 10 (885 Views)
04-13-2012 11:50 AM in reply to: CADastrophe
Did that and added an entry.  I am now getting blank lines in the building construction type menu on revit.  Ideas?
CADastrophe
Message 6 of 10 (879 Views)
04-13-2012 12:22 PM in reply to: zingero84
OK, this should work: Rename the file and change extension to a .txt file. Copy the section of text (highlighted below), Paste it to create a new entry.
Change the information between the declarations (i.e. <name> XXX </name>). Rename and change extension back to .xml.
Valued Mentor
julianjameson8403
Message 7 of 10 (873 Views)
04-13-2012 12:29 PM in reply to: zingero84
Have you tried using either notepad++ or xml notepad? You can download these for free from the internet and can make xml editing easier.
When editing are you abiding by the naming conventions of the constructions and their xml format? From memory I think there is a link between the naming convention of the constructions and the Ashrae guides DOE2.
Check out the gbXML schema explanations in the wiki, both the entry on the constructions xml file as well as the reference section on gbXML generally. I have found you have to be precise in the syntax of gbXML to get it to work properly, especially in the Revit environment.
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/3251-Referenc3251/3288-Heating_3288...
http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/3251-Referenc3251/3325-gbXML_Sc3325
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
Active Contributor
zingero84
Message 8 of 10 (854 Views)
04-16-2012 06:11 AM in reply to: zingero84
Ok, so it looks like Notepad++ works well.
Now, I created an entry, and checked to see if it worked.  It's listing the wrong u-value (different than the one I write in the code).  Here is the code (with the first entry being the one of copied from to make the custom).
Should I have different "id" values?  Where do these values reside?  Is this where it truly pulls the u value from?
<Construction id="con-w339" surfaceType="ExteriorWall">
<Name>Plasterboard, concrete block, air, concrete block, plasterboard</Name>
<Description>1/2 in (12 mm) plasterboard on battens, 4 in (100 mm) lightweight aggregate concrete block, 3 in (75 mm) airspace, 4 in (100 mm) lightweight aggregate concrete block, 1/2 in (12 mm) plasterboard on battens [Source: CIBSE] </Description>
<LayerId layerIdRef="lay-w339"/>
<U-value unit="WPerSquareMeterK">0.62</U-value>
</Construction>
<Name>Face brick, masonry mat, poly insulation, densglass, metal stud, gyp board</Name>
<Description>Brick veneer, 1" clear masonry mat, 3" poly insulation, vapor barrier, 5/8" type X densglass, 6" metal stud, 5/8" gyp board [Source: CIBSE] </Description>
<U-value unit="WPerSquareMeterK">0.0508389</U-value>
</Construction>
Active Contributor
zingero84
Message 9 of 10 (844 Views)
04-16-2012 07:03 AM in reply to: zingero84
Moreover, I tried creating new con-XXX groups and lay-XXX and mat-XXX groups and then using the meter length and conductivity to calculate the u value, and it didn't work.
CADastrophe
Message 10 of 10 (832 Views)
04-16-2012 07:47 AM in reply to: zingero84
I'm finding very little information on this topic, but here is a link with some instructional info. I don't think I can help much more beyond this...
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
