Is there a way to add System Classifications to a Revit project/template? The project I am working on has numerous plumbing piping systems, more than what is available in the default template and it doesn't seem like there is a way to get a pipe system re-classified to differentiate the new system from the system family it was duplicated from.
I have tried to duplicate the Domestic Hot Water System and to create the Domestic Hot Water Recirc System. I can get the linetype to display with the HWC linetype, but I would like to get it on a different color as well
I also need to add other Plumbing systems such as Lab CW, Lab HW, Lab HWC, and numerous Lab and Med Gas system types.
I am having a hard time getting the Visibility/Graphics Override displaying the Plumbing Plan template settings I have created.
So you've sucessfully duplicated a piping system already? You're most of the way there then.
I'll start from the top anyway because its easier. ...& from memory because my PC is busy procesing an IFC file so apoligies if this isn't exactly right..
HTH
Note, that if you create systems that do not have a corresponding connector type, you run into problems when trying to connect the pipe to equipment. I'm currently getting around this by setting the connectors to global, but it's not a very nice solution.
Keen to hear what others are doing.
