Hello All,
I need to create a slab with multiple sloped areas to floor drains. I am using Revit MEP 2014. How do I go about this? I cannot find any useful videos on Youtube.
Revit Noob
Solved by Alfredo_Medina. Go to Solution.
I don't know if Revit MEP has this tool, but, when you create a slab with the Floor tool of the Architecture tab, and you click on the floor, do you see some tools on the ribbon, like "Modify Sub-Elements"? If you do, those are the tools that you need to use for the slopes. Check the Help documents about "Modify sub elements".
