Revit MEP Forum
Create air handling unit
1 REPLY 1
FedericoAngeli
1623 Views, 1 Reply
I need to create an object (an air handling unit AHU) and I need to choose the size, thermal load (heating and cooling) and power of the fan.
The only data that I can change from an AHU in the library are the dimensions and the electrical load absorbed.
Can I enter this data in an object? how can I do that?
thank you very much
FA
1 REPLY 1
Hello there...
Open the family
go to create > family types> add parameter
For such things I would go for shared parameters instead of project parameters
Hope it helps;)
Cheers
Mehdi
