I try to open a revit file, but it gives me this message:
Revit could not find or read 1 references files. What do you want to do?
Unresolved CAD or DWF markup files will be displayed as they were when the project was last saved.
When I open it, I only show part of the revit file?
Is that there is a linked file nested inside ths one?
What is the problem?
Thanks!
Solved by CoreyDaun. Go to Solution.
Go to Manage tab » Manage Links to find out what links are missing. If the model came from another company, then you will not be able to reference the Lined CAD files on their local server, hence the error. You would have to obtain a copy of the CAD/DWF files and then click "Reload From..." to redefine the path to the linked files. Alternatively, if a link is of no use to you, you can select it and click "Remove" to eliminate this error.
Thank you CADastrophe!
I go to Manage links tab, click Revit item, it show Linked files : Arch_link.rvt
Status: Not Found.
Reference Type: Overlay.
Positions not saved:
In fact I can find the Arch_link.rvt file, it is in different folder.
Thank you!
