Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Continuous Linear Lighting Fixture
2 REPLIES 2
bvm76
2439 Views, 2 Replies
I am trying to model a continuous lighting fixture with no preset length. My goal is create an instance parameter to where I can put the length while on the project. I tried to make the "Length" as Instance Parameter but have a problem with the "Emit from Line Length" parameter (can't modify).
Any advise will be much appreciated.
Please mark Accept as Solution if your question is answered!
Thank You.
2 REPLIES 2
Alfredo_Medina
in reply to: bvm76
Select the light source object and change the default association of the "Emit from line length" property to your "length" instance parameter, instead of the default type parameter.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
So, this definitely works. Why does it work? Doesn't this break the rule of an instance parameter cannot drive a type parameter?
Rail Community
