Revit MEP
Valued Contributor
bvm76
Message 1 of 2 (283 Views)
Continuous Linear Lighting Fixture
283 Views, 1 Replies
02-02-2014 03:01 PM
I am trying to model a continuous lighting fixture with no preset length. My goal is create an instance parameter to where I can put the length while on the project. I tried to make the "Length" as Instance Parameter but have a problem with the "Emit from Line Length" parameter (can't modify).
Any advise will be much appreciated.
Alfredo_Medina
Message 2 of 2 (268 Views)
Re: Continuous Linear Lighting Fixture
02-02-2014 04:33 PM in reply to: bvm76
Select the light source object and change the default association of the "Emit from line length" property to your "length" instance parameter, instead of the default type parameter.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
