Revit MEP Forum
Connecting a 1 phase (230V) & and 1phase receptacle to a 3phase DB Panel
2 REPLIES 2
CPEdwg
651 Views, 2 Replies
Hi There,
I'm using Autodesk Revit MEP 2011 and can't connect a single phase Distribution Panel (DB) to a three phase DB, what must I do to be able to do this?
Also how can I circuit a 230V receptacle to a three phase DB?
Urgent help will be appreciated
Thank you
Gunther
2 REPLIES 2
julianjameson8403
in reply to: CPEdwg
You have to make sure you have the correct distribution system setup in the project (415/230V) and also the correct correct distribution system assigned to the panels and the receptacles.
When creating the distribution systems, you have to make sure that the voltage values match for the single phase and the individual phases of the 3 phase system.
Main Panel would have a 415/230V three phase assinged to it, the single phase pnael would have a 230V single phase distribution system and the receptacle would still be 230V single phase distribution system.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
CPEdwg
in reply to: julianjameson8403
Thank you, this helped me ALOT! Thanks
My other mistake was that I used 3 wires and not 4.
