hi
For Conduit We also like the pipe assigned Color Fill Legend?
For example, I need to set the color by Service Type.
Solved by abulla. Go to Solution.
What you want to do in this case is create different types of conduit using Duplicate from the type properties menu. Then, you can either create a parameter for Service Type, or use one of the existing parameters like Type Comments to fill in the service type. Finally, you need to set up a filter for conduits that looks at the service type parameter you're using, and you can assign a solid color surface pattern to that. I don't believe there is a color fill legend for conduit yet though.
hi
Hi and thanks abulla.
I enjoyed very much for your answer.
