Revit MEP Forum
Circuit problems
3 REPLIES 3
336 Views, 3 Replies
Circuit problems
Ok I am not that good at figuring out revit and am having a problem. I am trying to make a circuit in revit 2013 with a light fixture (277) and 480V panel.
This is what it keeps telling me.
Cannot assign or add H to Circuit. The Voltage (277 V) for the Circuit is out of range for the Line to Line Voltage for H (The Line to Line Voltage is specified in the assigned Distribution System).
Can someone help me out with this.
3 REPLIES 3
CoreyDaun
What Distribution System is your Panel set to? Also, please post an image showing your Electrical Settings: "Distribution Systems" and "Voltage Definitions".
in reply to: CoreyDaun
I am trying to circuit a 277 light to a 480 panel. I know this should work but can't figure it out attached are the (2) images that you requested.
Thanks for the help.
CoreyDaun
Everything appears to be correct with your Electrical Settings. It sounds like the Panel that you are attempting to circuit to is actually a 120/208V Panel - select that Panel and verify which Distribution System it is assigned to.
