I have a number of bends I want to change in one go.
They are all on the same system type, system abbreviation and size. They are currently Ø50-Ø50 and I need to them all to be Ø63-Ø63. I cant select all instances because I have Ø50 bends on another system that need to stay that size.
I've played around in a schedule for an hour and no joy, any help much appreciated.
Solved by CoreyDaun. Go to Solution.
The Schedule should be the way to go. Add the filed "System Abbreviation" and under the Filter tab (in Schedule Properties), set the condition to "System Abbreviation" "equals" and then enter the desired value. The field System Type" cannot be used in a Schedule's Filter. Set the Sorting/Grouping to "Size" and then disable the option "Itemize every instance" at the bottom. Now you should be able to click on a row and then click "Highlight in Model" to select them all so you can change them as needed.
