Revit MEP
Member
Message 1 of 5 (358 Views)
Changing Level within Callout
358 Views, 4 Replies
10-22-2012 04:54 AM
Good Afternoon,
I hope someone can help.
The Architect has changed the floor level on the job I am working on, I have adjusted the my floor plan to suit.
My problem is that I can't seem to adjust my callouts to match the new floor level so they show the correct area on my sheet, the area to change this in the Properties Box is greyed out?
Look forward to hearing from you
CADastrophe
Message 2 of 5 (354 Views)
Re: Changing Level within Callout
10-22-2012 05:33 AM in reply to: JHBMX
Are you using Revit MEP 2013? If so, the most likely cause for the View Range button being disabled is that there is a View Template assigned to the View. This would also account for other View settings (i.e. Detail Level, Discipline) being disabled as well.
If you aren't already aware, the View Templates workflow has been improved as the templates are now linked to Views.
Welcome to the Autodesk forums, JHBMX!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
Member
Message 3 of 5 (350 Views)
10-22-2012 06:09 AM in reply to: CADastrophe
Thanks for the help. yes I'm using 2013.
I unerstand what you are saying, yes there is a template set to the view in fact there are various templates set to all views (except sections).
Is there a way to set the view so it has no template applied to it? I can see no option.
Thanks so much for your time
CADastrophe
Message 4 of 5 (343 Views)
10-22-2012 06:37 AM in reply to: JHBMX
You now have your choice of two routes to take:
1. Remove the View Template from the View
Under the View's Properties, click on the button beside 'View Template' which is reporting the current View Template's name. Select "<none>" from the list in the following dialog box.
2. Correct the View Range in the View Template
Under the View's Properties, click on the button beside 'View Template' which is reporting the current View Template's name. Select the current View Template from the list in the following dialog box. In the list of View Properties on the right, locate the View Range and set it to the desired setting.
Alternatively, in lieu of changing the View Range, you can clear the checkbox under "Include" to exclude it from the View Template. This will allow you to change the View Range per View, but maintain uniform visibility settings for everything else.
I would recommend taking road #2 as well as learning and working more with View Templates. When changes arise, the use of View Templates can alleviate the painstaking effort that would be needed in going to each and every View to make corrections to view settings. Using this method, you can make a single correction to the View Template that will subsequently cascade down to all of the Views with this View Template, so you only have to make the correction once.
Member
Message 5 of 5 (304 Views)
10-23-2012 12:29 AM in reply to: CADastrophe
Great! thanks very much fixed it.
Thanks again
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
