Revit MEP
Member
chrissumner
Message 1 of 3 (1,138 Views)
Accepted Solution
Change pipe line type with invert level
1138 Views, 2 Replies
07-30-2012 07:41 AM
Ive been told i can use filters to change a pipes linetype by invert level but cant figure out how it works. I'd like to set up a filter so pipes shown below the floor are hidden (below level 0), at low level (from level 0 to 2400) are solid and at high level(from 2400-slab) are a centre line. I know there's an overhead linetype but its too similar to the hidden.
Ive looked through the filters and cant see an option to filter by invert level?
Any help appreciated.
Active Contributor
Message 2 of 3 (1,124 Views)
Re: Change pipe line type with invert level
07-31-2012 03:44 PM in reply to: chrissumner
I Chrissumer
i hope the images explain what you need to know. think its invert elevation your after.
Cheers
Guy
Member
chrissumner
Message 3 of 3 (1,100 Views)
08-01-2012 01:04 AM in reply to: gookeeper
Thankyou for taking the time to provide screenshots, the solutions works 100%
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
