Revit MEP Forum
Ceiling Gird
3 REPLIES 3
WheelerCJ
347 Views, 3 Replies
Ceiling Gird
I have a few default templates and Im trying to show the ceiling grid using one tamplate and I cant get it to show.
I have the view range set in my RCP and when I use one template it shows but when I switch it disappears. I've checked all the obvious things - ceilings turned on, Underlay is the same, Underlay Orientation is set to RCP. Changing the discipline makes no difference.
I can select the ceiling and it hightlights the boundary and shaded it in so its there I just cant see a grid.
Anyone any ideas?
3 REPLIES 3
jkarben
in reply to: WheelerCJ
Check that you have Ceiling surface patterns visible.
Visibility Graphics (VV/VG) > Model Categories > Ceilings Projection/Surface Patterns...Does it say Hidden? Click and check the visible box
WheelerCJ
in reply to: jkarben
Thanks for your reply.
That was ticked visible. 😞
CoreyDaun
Could it be that a View Filter is disabling the visibility of the Ceiling's Surface Pattern, similar to the way jkarben described, but in the 'Filters' Tab, instead.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Rail Community
