Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Can't get angle parameter to change w/out error
1 REPLY 1
626 Views, 1 Reply
I'm modeling a water heater and I need my hot outlet to come out the side on some and the top on others. I created a sweep for the outlet and dimensioned the angle. But, when I change the angle in the Family Types from 90 to 0 degrees I get this error:
- Error (must be addressed in order to continue)
 - Constraints are not satisfied
  - Error 1
    - Reference Planes: Reference Plane: Center (Left/Right): id 48
    - Lines: Model Lines: id 26693
    - Dimensions: Angular Dimensions Style: Parameter: id 26902
PS: Is there any place out there where I can access help specifically for modeling equipment? It seems like all the help locations for Revit MEP are only for architecture design. I know this is what Revit is for, but I know that there are a lot of manufacturing companies that are using Revit for modeling equipment only, as I am. Surely they get specific help or instruction from somewhere.
PPS: Using Revit MEP 2011.
1 REPLY 1
CoreyDaun
Rotating components can be quite touchy in Revit. My typical method of creating rotating components is host the extrusion(s) to a Reference Plane that is rotated. Check out >this thread< and see if you can get it to work. If not, just post back here and I'll take a closer look at what you've got.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
