Revit MEP Forum
Can I change the name of the tag?
2 REPLIES 2
975 Views, 2 Replies
When I load tag on the drawing, can I change the name of the tag? for example, the tag I loaded is called C,  can I change it to another name which I want…as I tried to double click the letter C, but it seems nothing happened?
Thanks!
2 REPLIES 2
CoreyDaun
In the Project Browser, right-click on the name of the Tag's Family or Type and select "Rename..." from the menu.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
Thank you CADastrophe! It works!
