When I load tag on the drawing, can I change the name of the tag? for example, the tag I loaded is called C, can I change it to another name which I want…as I tried to double click the letter C, but it seems nothing happened?
Thanks!
Solved by CoreyDaun. Go to Solution.
In the Project Browser, right-click on the name of the Tag's Family or Type and select "Rename..." from the menu.
