Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Callout Bubble changed to arrow.
1 REPLY 1
827 Views, 1 Reply
Is there a way to change a callout from using a bubble to using an arrow to point at the object being called out?
If not, is there a way to keep details referenced and have them kept connected like a callout?
Example:
Plan view- Mechanical Equipment (being pointed to)callout showing (MP501 detail 3) **no bubble, arrow pointed at it.
Detail Sheet- Mechanical Equipment Detail (ref as MP501 detail 3)
Help is much appreciated.
1 REPLY 1
CoreyDaun
This is not currently possible. I tried an experiment in using a View Reference Tag to accomplish this, but to no avail.
You have a good idea here. What if a Drafting View could be assigned to a Model Element as a detail? Then a View Reference Tag would work very well. Perhaps a post in the MEP Wishes forum would be appropriate...
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
