Revit MEP
Valued Mentor
gh_ar
Message 1 of 3 (142 Views)
Calculating the length of conduit
142 Views, 2 Replies
01-07-2014 06:56 AM
hi
I am trying to calculate the total length Conduit ,Calculate the length without fittings ,I need to calculate the length of the segmentalong with fittings.
The solution is to perform this calculation?
CADastrophe
Message 2 of 3 (126 Views)
Re: Calculating the length of conduit
01-07-2014 09:15 AM in reply to: gh_ar
I believe that you would want to use a Conduit Run Schedule, and not just a Conduit Schedule. A Conduit Run Schedule will automatically calculate the total length of a series of connected Conduit segments and bends that belong to a "Conduit without Fittings" Type.
If you wish to differentiate between different Conduit Runs in your Schedule, use the Comments parameter as a label. You can either enter a value directly into the Schedule or select the entire Conduit Run (hover over with the cursor and hit TAB) and enter a value for Comments in Properties.
Valued Mentor
gh_ar
Message 3 of 3 (123 Views)
01-07-2014 09:26 AM in reply to: CADastrophe
Hi CADastrophe
Yes, that was exactly I mean and Thank you very much for your answer.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
