Revit MEP
Active Contributor
ArynBergman
Message 1 of 2 (491 Views)
Calculating cable lengths from different pathways along cable tray networks
491 Views, 1 Replies
06-27-2013 09:16 AM
Hi, we need to develop a way to calculate the lengths of fibers based upon pathways along a cable tray network within a datacenter that are associated with the cables between particular patch panels.  The Revit wire tool for electrical circuits sort of does what we need, but it's clumsy to use and not accurate enough.  It doesn't look like it takes into account changes in elevations, but please correct me if I'm wrong.  Here's what we're currently thinking as our best option:
  1. Add a length parameter to the cable tray fittings, add a pathway parameter to electrical circuits, and add a label parameter the cable tray runs and fittings.
  2. Drop in the equipment.
  3. Draw the cable tray.  Label the trunks and branches, i.e. T1, T2, B1, etc.
  4. Create the circuit and add a shared/project parameter for the pathway and add the cable tray trunks and branches it's supposed to follow; i.e. T1.T2.B1.B2.
  5. Export the cable tray to a spreadsheet.
  6. Export the circuits to a spreadsheet.
  7. Use the circuit's pathway parameters to reference the trunk and branch labels of runs and fittings and their associated lengths in the cable tray spreadsheet to calculate the overall required cable length for the circuit.
If anybody has a method that they're currently using or if you have any ideas on how to streamline the above process, please share.
Thanks in advance.
New Member
Gary_Hicks
Message 2 of 2 (372 Views)
Re: Calculating cable lengths from different pathways along cable tray networks
08-29-2013 01:47 PM in reply to: ArynBergman
Shipconstructor electrical is a program that is just being introduced, for this. The program is a part of autocad, or tied to it. South alabama in Mobile , Alabama has a person there that is teaching the program.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
