I am attempting to use the Revit COBie Toolkit 2014 to export a fairly large MEP model. When I press "Select Elements to be Exported" I get the attached error. Anyone ran into this before?
Solved by bbrown. Go to Solution.
BBrown,
Did you go to setup, modify module prior to export? You will need to setup and modify (verify assets) before you export to XLS.
I forgot about this post, as it was awhile ago. I contacted the developer of the plugin and it was a bug. We were able to work it out together. If you have any problems, contact their support and they will give you a hand. They were really responsive.
