Show only
Search instead for
CAD Imports appear halftone when imported on reflected ceiling plan.
When I import a CAD file into revit i use current view only and black and white lines, but for some reason it shows up like it is halftoned and wont print out correctly. If someone knows how to fix this please let me know
Do you mean AutoCAD imports? or some other CAD package?
You have to make the view a coordination view, or an architectual view to get them to print in black.
Imports also drag down the model speed. Its better to draw it properly in Revit if you can.
Thanks a lot, that worked like a charm. Yea I had an AutoCAD import of some rev clouds i did because it takes way too long to draw it in Revit. I know it probably slows it down but right now im in a hurry.
