Revit MEP
CADastrophe
Message 1 of 3 (136 Views)
Broken View Filter
136 Views, 2 Replies
04-26-2012 09:30 AM
In an effort to create a visual aid for Electrical Circuiting on a lighting plan, I created a couple of View Filters to color the lights based on Circuit Number. Nothing special.
..And the filters are indeed set up on the View:
However, one of the filters is not doing it's job. These light fixtures are Tagged on the view:
Now, endless tweaking of the filter "Electrical Circuits 9&10" led me to believe that some glitch has occurred:
And somehow the filter catches that light fixture now. Huh? As far as I know, 9 is not "Greater than or equal to" 28461.
Has anyone ever seen this behavior before? (And I apologize for the huge post!)
Valued Mentor
dennis
Message 2 of 3 (116 Views)
Re: Broken View Filter
04-27-2012 12:27 PM in reply to: CADastrophe
Yep, it isn't working at my house either.  I setup Fitlers just like you, and seems only the Circuit9&10 filter doesn't work.  It acts like it doesn't understand the number < 10 >.  But I did check for 11&12, which did work.  I did try Equals 9 only, which worked, and Equals 10 only, which worked.  The problem seems to be fixed into 2013 as well.  Also, not sure, but it seems to not work with certain light fixtures, particularly the Troffer Light.  My 2013 test had both the Troffer and Emergency lights, the Emergency lights work, the Troffer don't.
CADastrophe
Message 3 of 3 (108 Views)
04-27-2012 01:09 PM in reply to: dennis
I also found that if you set the 9&10 to "Greater than or equal to: 43874" (just like in the image in the original post) and move this filter to the top of the list, it now hits all of the light fixtures (or whatever electrical devices) except for circuits 1 and 11. There is some internal logic error occurring here.
I thought this was just an error within our project - thanks for the research!
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
