Revit MEP Forum
Best way to work with AutoCAD files in Revit
4 REPLIES 4
Mehdi.Kardehi
734 Views, 4 Replies
Hi All,
Seeking you advice on the best practice to work with AutoCAD files in Revit.
I already have a procedure in place that I import all CAD views of architectural drawings to Revit (I put all 2D drawings in where they should be to make a 3D drawing). Then I do all the designs in Revit and when I am done I export them as pdf and dwgs
Is there any down fall to this? Is there a better practice out there?
Thanks for your help in advance,
Cheers,
M
4 REPLIES 4
russellvee
in reply to: Mehdi.Kardehi
I like to link the architect's DWGs to each view and use it as the background for my sheet views. I only model the architecture that is necessary for my MEP elements to attach to, then turn all that stuff off for the sheet views.
I have heard that importing large cad files will seriously affect the file size and most of my projects are around 100 MB so I try to avoid importing.
Mehdi.Kardehi
in reply to: russellvee
Thanks for the propmt response
Up to now the architects used to send me dwg and recieve dwg or send me Rvt and recieve Rvt...because I made a switch to Revit I prefer to avoid using AutoCAD and this architect has supplied me dwg files
I pretty much do the same.. and it looks perfect when I hand in my designs in pdf format
but what about when you export it to dwg for the architect? any down falls there?
Do architects actually need dwg files or a properly dimensioned pdf does the job for them?
russellvee
I don't typically have to deliver DWGs to the clients, but when I export to DWG it attaches the architectural background as a separate xref with all my layer control, which seems to work fine.
I think using a 2D background is crucial for plumbing drawings. On a multistory building I like the cut plane set below the floor level so I can show the sanitary piping, but I don't want to show architecture from the floor below. Maybe if they had separate MEP view depth and architecture view depth settings.
Mehdi.Kardehi
Thanks for sharing your exp with me mate
