Revit MEP
Active Contributor
sujeev
Message 1 of 7 (1,085 Views)
Accepted Solution
BOTTOM OF DUCT JUSTIFICATION
1085 Views, 6 Replies
03-05-2012 11:30 PM
Hi
How can i set my bottom of duct justification. presently it is center of the duct and i want to change it to the bottom of duct. i draw a duct 1000x600 with BOD 3900. and when i check the property of that duct it is showing that offset from floor level is 4200. (ie floor to center instead of floor to bottom of duct) how can i set this..
Valued Mentor
julianjameson8403
Message 2 of 7 (1,082 Views)
Re: BOTTOM OF DUCT JUSTIFICATION
03-06-2012 01:58 AM in reply to: sujeev
When you select the duct tool, one of the options on the ribbon is for Justification. You can set the preferred justification there and a horizontal offset (if using 2012).
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
Active Contributor
sujeev
Message 3 of 7 (1,075 Views)
03-06-2012 02:06 AM in reply to: julianjameson8403
I tried to do that. but still the problem exists.. it is fine when i draw the duct. but soon after that when i check the property it is showing elevation height from floor to center of the duct instead of to bottom of duct.
I think there will be some default setting..
Valued Mentor
julianjameson8403
Message 4 of 7 (1,070 Views)
03-06-2012 02:40 AM in reply to: sujeev
Any particular reason you decided to underline your reply as my initial reply answered your initial question????
The offset refers to the centreline which also happens to coincide with the duct placeholder tool.
The justification tool allows the elements to be aligned differently and also helps place the duct with the determining location line at the required level when modelling.
The duct offset parameter in the duct properties relates to the centreline of the duct
There are also Bottom Elevation and Top Elevation parameters which display the information you are looking for and also available for tagging.
Thank you!
Active Contributor
sujeev
Message 5 of 7 (1,067 Views)
03-06-2012 04:40 AM in reply to: julianjameson8403
sorry....may be i happened to click underline tool...and i didnt notice it much....
ya i found what it means veritical justification. and thanks for pointing out bottom elevation that is what exactly i was looking for.  before i was confused with offset level.
still one more doubt... now the duct level is showing correctly in the bottom elevation coloumn. but it is not editable. can i edit that coloum???
sorry again for the underline stuff
Valued Mentor
julianjameson8403
Message 6 of 7 (1,072 Views)
03-06-2012 04:56 AM in reply to: sujeev
No worries.
The top and bottom are not directly editable as they they are calculated from the difference between the centreline and the half height of the duct.
As these parameters are greyed out - I don't believe you can amend them directly through the Revit interface. You could do it via an Excel linked import/export tool (external Add-in or via the ODBC database subscription tool) but you run the risk of breaking your model using that method if you have conflicting information in parameters used in calculations, etc.
Thank you!
Active Contributor
sujeev
Message 7 of 7 (1,065 Views)
03-06-2012 05:02 AM in reply to: julianjameson8403
Hi
That looks difficult to me since i am a beginer in revit. I will have to look at these import/export excel files. Thanks for the help. Now atleast i know where i have to look..
for me the problem occurs when i tried to allign (all bottom levels same)  some of my ducts to certain level. the ducts are of different heights. and i was looking to change them directly from the properties tool bar.
Thanks for the help...any tips regarding this always welcome
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
