Revit MEP Forum
Welcome to Autodesk’s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
BIM Exchange Material Issue
4 REPLIES 4
385 Views, 4 Replies
Hello All,
I am using both Inventor Professional 2013 and Revit Architecture 2013. When I design a part in Inventor, I have no issues with getting the physical part to go into Revit using BIM exchange, but my set materials in Inventor do not tranfer. The object imports as a black and white solid object. Anyone else have this issue or know of any suggestions to fix it?
I attached an example of what I mean.
4 REPLIES 4
Anyone?
CoreyDaun
You image shows that you have the View's Visual Style set to 'Hidden Line'. Try changing it to 'Shaded' or 'Realistic'.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
in reply to: CoreyDaun
I had originally thought that may be the issue when I had first imported it, but none of the visual styles change the appearance either.
CoreyDaun
I don't have Inventor to experiment, but I don't believe that there is a good translation between the two. To my understanding, most of the data from Inventor files is lost, as they are inserted as plain geometric object in Revit.
