In Revit 2013 MEP
I just placed a 6" valve on a 6" copper line, Later I needed to place a 3/4" ball valve on a 3/4" line. So I go to the Pipe Accessory button and invoke the process. I hover over the 3/4" line and it still remembers the 6" valve placed earlier. My question, Is Revit not smart enough to know that the line is 3/4" and not 6" ?
That's hard to believe... That it can give use all these calculations according to fixture units but not able to distinguish between pipe sizes.
PV
Solved by stearnskl. Go to Solution.
The size of some Families are controlled by Type Parameters, such as the Ball Valve family, and the desired size must be selected via the Type Selector (the pull-down on the top of Properties). Can you attach the Family file for the ball valve?
The OOTB content relies on the user to select the type (size) of valve to place in the pipe.
Some firms have made their own, or have modified the families to read the pipe size and adjust the family automatically. We have accomplished this by using formulas in the family. Its a lot of work, but worth it in my opinion.
Well shut the front door. I retract my previous post. Thanks for fixing our valves Stearns. Goofy that it isn't that way OOTB.
Thank you all for your helpful replies. I found out that when someone requires an object they will tend to load them from were ever they can find it. Some from vendors, others from our standard files and still other from older versions of Revit families.
We will have to get in the habit of using only certain families designated for that project.
Thanks again.
Perhaps in your experience it's normal for people to seek families on the internet or out of the box. In my experience, some families others created (including autodesk) are not up to par or inaccurate. Big purple R --> New --> Family is what works.
Trying to force Revit to automatically select a valve size is a no-no especially for control valves. Your oversized pipe would force an oversized valve that will be terrible at getting the flow required and would be an expensive on/off valve.
So to have REVIT automatically size the valves for you and be inline with pipes, those valve families must probably not have multiple types within that family and must use a lookup table? I've created lookup tables before but they're more cumbersome than creating multiple types and using type parameters. I've created dampers that REVIT can automatically places inline with the duct (without me splitting the duct or editting the nominal height and width of the damper), but they have all instance parameters. With valves, the construction is a bit more complex and dimensions typically don't follow any general formula. I typically create many types within a family (each type is associated with a valve size), and simply right click, create instance (of the valve + size I want) and have REVIT stick it inline with a pipe.
Is that a little more complicated than having 1 default type and letting REVIT automatically size it? Sure. Does having 1 valve type save a little time should you resize the pipes (and REVIT automatically resizing the valve)? Sure.
If it works for you, then keep on doing what you're doing.
