Hi All,
This has created a Conundrum for me. Please help me understand what the relationship and usibility of the Other air and Global connector is if Ashrae duct fitting types only support loss coefficient for Supply,Return, Exhaust and Common.
EXAMPLES
1. AHU that has a Supply and Return ducted and Outside air (Fresh air) not ducted with a damper on AHU.
The Connector for outside air then has to be a return connector with flow direction in calculated??
The Louvre in wall has return connector with flow direction out Preset.
2. AHU that has a Supply and Return ducted and Outside air (Fresh air) ducted with a damper on AHU.
or both have to be supply connectors.
a) What will it be to ensure general use of the Louvre ( Supply, Return, Fresh, Extract) or should one of each be created.
b) How and where is Other air and Global used and how does it affec the correct pressure drop calculations gotten from the Ashrae xml file in Revit.
Then the same question goes for the piping conectors Global and Other??? how is it used to achive correct flow and pressure calculations
Thanking all in advance and looking forward to response.
Regards
Marius
Marius
Have you looked on Kyle Bernhardt's blog (Inside the system) where he did two posts on connectors? These may help explain a little more the principle behind the Autodesk idea of conenctors. In response to your questions:-
Have you reviewed the help file on the connector type descriptions to help explain where you would use Global connectors?
Regards
Julian
