Revit MEP
norcaljess
Message 1 of 10 (466 Views)
Annotation Symbol in Electrical Family
466 Views, 9 Replies
02-11-2013 07:27 AM
I'm attaching my electrical switch family that I have created.  The reason why I have nested the plate & fixture box families separate is because we need each instance to show up in a schedule.  My problem is that I can't get the $ switch symbol to show up on my plan when I insert the family.  I've tried looking at other switch families where the $ symbol shows up but I must be missing a step.  Anyone know what that is?
Jess
CADastrophe
Message 2 of 10 (460 Views)
Re: Annotation Symbol in Electrical Family
02-11-2013 07:42 AM in reply to: norcaljess
What template did you start with when you created this Family?
norcaljess
Message 3 of 10 (458 Views)
02-11-2013 07:45 AM in reply to: CADastrophe
:smileyfrustrated: I started with an Electrical Fixture template, the reason being, I have almost an identical family for Recepts that I created first, then used that to create this one.  Should I start over with another template?
Jess
norcaljess
Message 4 of 10 (454 Views)
02-11-2013 07:48 AM in reply to: norcaljess
And as far as the template I used to create the Recept family, I started with a 'Generic Model face based' because I want the Recept & Switch families to cut holes in the walls that host them.
CADastrophe
Message 5 of 10 (450 Views)
02-11-2013 07:53 AM in reply to: norcaljess
No need to recreate, that should be OK. Open your Family and go to Family Category and Parameters. Check the option "Maintain Annotation Orientation" - that should fix it.
norcaljess
Message 6 of 10 (448 Views)
02-11-2013 07:56 AM in reply to: CADastrophe
:smileymad:  AAAAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!!!!!!!
Thank you Corey!!!!
CADastrophe
Message 7 of 10 (443 Views)
02-11-2013 08:02 AM in reply to: norcaljess
norcaljess wrote:
":smileymad:  AAAAAAAAARRRRRRRRGGGGGGGGGHHHHHHHHHH!!!!!!!!!!!!!!"
Breathe...just breathe.  At least it was a simple answer this time, in lieu of the traditional 15-paragraph explanation/work-around!
norcaljess
Message 8 of 10 (419 Views)
02-11-2013 12:34 PM in reply to: CADastrophe
That's what makes me so mad!  I am overthinking things because that's what I normally have to do with Revit, and it was a stinking check box!  And one that I had considered checking to see if it would fix my problem!  BUT I decided it just couldn't be that simple and let it go.  Revit... teaching me a lesson again!
CADastrophe
Message 9 of 10 (416 Views)
02-11-2013 12:48 PM in reply to: norcaljess
Well, if it makes you feel any better, I really didn't think that would work, either...
Oh, well. All you can do is laugh - 'cause if we're not laughing, we're crying. Or throwing our computer across them room...
norcaljess
Message 10 of 10 (413 Views)
02-11-2013 12:55 PM in reply to: CADastrophe
Or... if you are one of the guys I work with... hurling verbal insults at Revit, as if it can understand you or has some personal vendetta against you.  :smileywink:
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
