We have building design suite premium 2014 installed on our machines, however when I try to link Amtech Pro Design to the Revit software i get an error saying Amecth can not find Revit installed on this machine. Has anyone else had this problem? Amtech has stated it is a Autodesk problem and not their software.
It could be that the plugin is looking for a different version of Revit that gets installed with the design suite. I know that there are multiple feature codes for Revit that cause licensing headaches with the suite flavors. I suspect you might be experiencing the same fate. You might ask the company how it validates the version so you can make sure. Just a thought.
We have the same problem. It would seem it is only compatiable with MEP which would appear to differ from design suite!! 😞 Anyone managed to get it to work??
