Revit MEP Forum
Air terminal Tag Functionality
1 REPLY 1
max.a.hollander
1251 Views, 1 Reply
I would like to combine two tags in to one.
I have a Air Terminal tag that gives me the neck size of the AT for a round connection and one for a rectanglar connection.  I would like to write a parameter that if round it will show the round tag and if rectanglar it will show the rectanglar tag.
I have attached both tags
Tags (3)
1 REPLY 1
CoreyDaun
in reply to: max.a.hollander
This cannot be done within the Tag Families - all the Tags are capable of is reporting the value of parameters. They cannot interpret this data or otherwise rely on a formula that relies on the values within the Tagged Family.
Can you attached a sample Project file with two air terminals (one round and one rectangular) with these Tags?
