Revit MEP
Valued Contributor
lsop1409
Message 1 of 5 (239 Views)
3D Generic Zones in Revit/Revit MEP
239 Views, 4 Replies
12-04-2012 08:51 AM
Hi
I need to create a model that shows generic zones for my services. i.e. A model showing corridor 'extrusions' for ductwork, pipework, containment and a lighting zone, all shown as different colours. This is to show a conceptual design model/general routing of services.
I can only think of doing this using ductwork to represent each zone and applying filters for the colours and applying a medium detail level (to remove flanges etc), as the ductwork cannot look like ductwork and needs to look like an extrusion.
Does revit/revit mep have any functionality to provide general 3D zoning/extrusion, does anyone know of a better way to achieve the above?
*Expert Elite*
abulla
Message 2 of 5 (236 Views)
Re: 3D Generic Zones in Revit/Revit MEP
12-04-2012 09:10 AM in reply to: lsop1409
I would think an In-Place Mass would work for this purpose, maybe make them different materials to distinguish the different systems.
Valued Contributor
lsop1409
Message 3 of 5 (231 Views)
12-04-2012 09:27 AM in reply to: abulla
Thanks, i am not familiar with masses. I have only seen 'create a new conceptual mass' option when you want to create a new file, could you point me in the right direction please?
*Expert Elite*
abulla
Message 4 of 5 (226 Views)
12-04-2012 09:37 AM in reply to: lsop1409
Sure, it's under the Architecture tab in 2012 (it's under Massing & Site in 2013), then In-Place Mass. Sketch it like you would an extrusion, then you can move it to the levels you want, and assign a material to it. I used different glass materials because of the transparency.
Valued Mentor
julianjameson8403
Message 5 of 5 (211 Views)
12-04-2012 11:12 AM in reply to: abulla
But bear in mind that it is good practice to create masses for each zone you are trying to indicate on each floor. you shouldn't copy the same in-place mass from one floor to another otherwise you will have problems when you come to edit them later on - as the design will undoubtedly change between now and then.
The intention of an in-place mass is that it is a "one-off" family that doesn't repeat in the model.
If my reply answers your query, please use the Accept as Solution.
Please give Kudos as appropriate to enhance the value of these forums.
Thank you!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
