Revit MEP Forum
Welcome to Autodeskā€™s Revit MEP Forums. Share your knowledge, ask questions, and explore popular Revit MEP topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
2014 fitting angle
1 REPLY 1
revitworkbench
282 Views, 1 Reply
2014 fitting angle
Does anyone know if it is still possible to schedule fitting angles in revit 2014? I dont see it in my available fields anymore. thanks
1 REPLY 1
CoreyDaun
in reply to: revitworkbench
The Angle parameter wasn't directly available before, either. There is a work-around method that involves creating a Shared Parameter (Angle), adding it to every applicable fitting family as an Instance Parameter, and setting the formula to "= angle" (or whatever the name of the controlling angle parameter). This Shared Parameter could then be Scheduled and Tagged to retrieve the fitting's Angle.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€ā”€
āž|āž Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
