Im using specific angles for ductwork in 2014 I have it set to 90, 60, 45 & 30 but I want to add 15 degrees but is not on the list is there a way of adding it or changing the 11.25 to 15????
Solved by luna.ye. Go to Solution.
Hi Chris,
At this time,there is no way for your to add or delete angles from that table. If you need to use 15 degree bends, I suggest that you can use the increment setting and set it to 15 degrees.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
