Revit MEP Forum
15 degrees duct fittings
2 REPLIES 2
chris.kershaw
604 Views, 2 Replies
Im using specific angles for ductwork in 2014 I have it set to 90, 60, 45 & 30 but I want to add 15 degrees but is not on the list is there a way of adding it or changing the 11.25 to 15????
2 REPLIES 2
CoreyDaun
in reply to: chris.kershaw
Currently (as of Revit 2014), the list of Fitting Angles is preset and cannot be modified or added to.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
luna.ye
Hi Chris,
At this time,there is no way for your to add or delete angles from that table. If you need to use 15 degree bends, I suggest that you can use the increment setting and set it to 15 degrees.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
