Revit MEP Wishes (Read Only)
timscherer1437
1617 Views, 1 Reply
pipe slope tag
can you create a tag for sloped piping.
1 REPLY 1
CoreyDaun
in reply to: timscherer1437
This issue should be posted in the standard Revit MEP forum and not the Wishes forum. But yes, you can create a Pipe Slope Tag. Create a new Tag Family or open an existing one for editing if you wish to add the info to that one. Create a new label or select the existing one and click "Edit..." under properties. Add the 'Slope' Parameter and load into project. It will take the formatting as defined in the project. Reply back if you need more info or run into any problems...
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
