Revit MEP Wishes (Read Only)
jfosteriii
97 Views, 3 Replies
Undo
When performing undo commands, I believe that it would be beneficial if Revit automatically reverted back to the view that the undo is being performed in. Currently, when undo is performed it can be done in a view that is no longer open making it possible to accidentally undo a command without being aware that it was undone.
3 REPLIES 3
in reply to: jfosteriii
? It does.... ? Except in a few instances....
wrote in message news:5669306@discussion.autodesk.com...
jfosteriii
It seems that those "few instances" happen quite frequently. I would think that if zooms, and views were incorporated into the undo process that it would abate the instances entirely.
channond
Couldn't agree more. It is very frustrating when you are undoing something you can not see it being undone.
