It appears that you can't associate a parameter with the radius of a radial array, although you can associate a parameter with the number of elements.
I encountered this problem when I tried to create a family of plate flanges. I can set up parameters to control the flange OD, ID, and thickness, and I can create a bolt hole and control its diameter. But when I array the hole, the only parameter I can assign is tne number of array elements.
