Revit MEP Wishes (Read Only)
MORE COLOUR PLEASE!
9 REPLIES 9
Message 1 of 10
1822 Views, 9 Replies
MORE COLOUR PLEASE!
We're Hydraulic Designers and the industry is screeming to have pipe systems in 3D in COLOUR!!!
9 REPLIES 9
Message 2 of 10
Revit can do this without any problem.
Message 3 of 10
THat's great news! But I've just sat through 3 days of REVIT training and was told consistently that there is no way to identify pipe runs in colour in 3D view (unless you 'paint' each individual element!).....
Message 4 of 10
asommer
I have about 20 different pipe types on one of my projects, I have used "Filters" located in the Visibility/Graphic Overrides to set different colors to all different types.  You just have to play with the filter settings a bit.
Message 5 of 10
in reply to: asommer
It works beautifully! Thank you all.... I will have great pleasure advising our 'trainer' of this revelation.
Message 6 of 10
embolisim
It's name and shame time!
Who on earth told you that rubbish? Its one of the more basic things to do.
Message 7 of 10
Hugh_Compton
How do you apply a material to a Pipe Type?
Message 8 of 10
CoreyDaun
in reply to: Hugh_Compton
As far as I know, one cannot apply Material to a Pipe Type specifically; it's defined by the Pipe System's Properties.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 9 of 10
Hugh_Compton
Hang Fire, I think I've just cracked it!
When a piping segment (under settings) is first created there is a dialog that asks what material to make the pipe from - simply select a material and your good to go....
I've attached a jpeg for more information.  I've tested it with a multi-material valve attached to the pipe and the valve retains it's materials....I'll need to test this a bit more but it seems to work 🙂
Message 10 of 10
CoreyDaun
Let's direct this conversation into the normal MEP Forum, shall we?
http://forums.autodesk.com/t5/Autodesk-Revit-MEP/Assigning-materials-to-pipe-for-visual-purposes-Cop...
