Revit MEP Wishes (Read Only)
james25
723 Views, 2 Replies
Curved Duct
I am working on an auditorium that has a curved back wall. We would like to place the duct against the wall. I haven't quite found a way to draw that in revit.
2 REPLIES 2
Martin__Schmid
in reply to: james25
You can approximate this with a in-place duct fitting (re attached .jpg). Unfortunately, you can't tap off of a duct fitting, but if you get the ducts close to it, it may be 'good enough'. I've seen customers take similar approaches due to this limitation. Of course, you lose the 'flow' information through the duct... but at least you can approximate the physical model.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
james25
Thanks for the reply. The in-place duct fitting worked out pretty well. It looks a lot better than my original duct created by approximating the curve using straight segments
