Revit MEP Wishes (Read Only)
Create Mulitple Light Sources
4 REPLIES 4
Jarom05
317 Views, 4 Replies
I think it would be advantageous to be able to create multiple light source in a family.
4 REPLIES 4
SamuelAB
in reply to: Jarom05
You can already do this by embedding them. However, they will not partake inthe Illumination calculation.
adam.jw
in reply to: SamuelAB
Nest your light families.
I've done this with theatrical light fixtures I've created. Since I want to throw different colors of lights when I render a stage scene (Revit nerrrd).
1. Make a light fixture family and create a light source.
2. Modify the light source and save out different versions.
3. Make a new light fixture family and load your saved out light fixture families into this new host.
4. Create a new parameter:
the image
Whether or not you want it to be an instance parameter is up to you. You can make it a type parameter if you want it to do something specific.
This might be handy if you have say, a recessed parabolic or troffer, with different lamping. The different lamping can change both the IES values and the model properties. Or you might have strip lighting, where you want to have multiple heads in a single family. This will solve this too.
ALTHOUGH I DO AGREE. It would be nice to have multiple light sources in a family!!!!
---Adam
____________________________________________________
Please give kudos to the MEP Wish List ideas you like, as this will help the Revit development team prioritize functionality additions!
SamuelAB
Do not forget to make the embedded lights Shared, else they will not read in the schedules.
adam.jw
Good call! Although it can get confusing if you have a bajillion lights in a project.
Naming conventions and standards becomes extremely important at this point.
