In having to go through numerous differently shaped rooms centering fixtures and devices, I've found drawing dimension lines, click EQ, deleting them, and clicking unconstrain to be cumbersome. Could there be a tool in which you select two aligned faces (like a dimension) and then select an element's plane to align centered between them?
there is Snap To midpoint of 2 point in autodesk that I would use for this, I think the description of your proposed tool is nice.
just pick an object then pick the 2 objects you want it centered on, then have the option to lock it the same as any other align tool.
lighting layouts would be so much easier.
