Is there a permanent fix for the worksharing dialog box not showing. this is a problem where the process starts and runs but the dialog box never pops up, it has to do with the Worksharing Monitor waiting on another process [typically a Windows process] in the Task Manager. You can temporarily fix the problem but it often comes back.
Any thoughts or solutions?
Thanks!
Solved by alan.quinn. Go to Solution.
See this link: http://revitclinic.typepad.com/my_weblog/2010/02/troubleshooting-worksharing-monitor-process-but-no-...
Thanks for posting.
HI.. We have a server project .. which saved as central throw RSN.INI file in server .. we made locals files in workstations .. but when run WORKSHARING MONITOR is getting and connectivity from server file " CANT MONITOR"" please help us?
Try to uninstall any Logitech software you have on your machine. That helped my problem..
A client recently told me that they had conflicts with iTunes that affect this situation, removing iTunes cleared it up for them.
