Revit Architecture
New Member
Message 1 of 4 (486 Views)
why imported dwg 3d model not show in plan but show in Section
486 Views, 3 Replies
03-12-2013 03:35 AM
hi everyone i have just started using revit.
i imported a 3d dwg file into generic model family and loaded into my project.(please see the attachment)
for some reason, the model shows in section, elevation and last level
of my floor plan and site plan as well, but it is not showing in my 1st to
2nd last floor plan. can some people tell what are to possible reason for this?
how can i get it show show in the plans?
thanks you so much
kindly regard
Alvin
*Expert Elite*
LisaDrago
Message 2 of 4 (446 Views)
Re: why imported dwg 3d model not show in plan but show in Section
03-12-2013 01:09 PM in reply to: alvin87812
Hello and Welcome to the Discussion!
How did you bring it in? the options...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 4 (429 Views)
03-12-2013 08:56 PM in reply to: alvin87812
"not showing in my 1st to 2nd last floor plan"
You probably need to set the "view range" for those levels.
*Expert Elite*
constantin.stroescu
Message 4 of 4 (415 Views)
03-13-2013 12:37 AM in reply to: alvin87812
  • It is possible that when you made the Insert dwg> import CAD you checked the option Curent View Only
  • In the levels in which you don't see the imported dwg look if in Properties > Visibility/Graphics Overrides > Imported Categories > Visibility , the inserted dwg object  is checked . It happend to me that an inserted dwg had also some hidden layers. Control the layers visibility
  • Check the View Range from Properties
Constantin Stroescu
BIM Manager AGD
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
