Revit Architecture
Distinguished Contributor
kwg06516
Message 1 of 2 (170 Views)
Accepted Solution
why am I seeing tops of components above the current cut plane?
170 Views, 1 Replies
09-13-2013 07:09 PM
I made this custom plate W-shape for my as-built from hell and for some reason I can see the top even though it's over six feet above the cut plane.  I changed another column (a W-shape from the Imperial library) to the custom and the top is not visible.  It's cut like it should be.
I should be designing by this point and I'm still as-builting this project.
AutoCAD 2010
AutoCAD LT 2013
Revit Architecture LT 2013
*Expert Elite*
constantin.stroescu
Message 2 of 2 (130 Views)
Re: why am I seeing tops of components above the current cut plane?
09-14-2013 01:45 AM in reply to: kwg06516
In Family Editor: Modify > Family Category and Parameters >Family Parameters >Parameter > Show family pre-cut in plan views - uncheck this option > reload the family back into the prokect....you will be able to see now , the correct cut...
Constantin Stroescu
BIM Manager AGD
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
