I made this custom plate W-shape for my as-built from hell and for some reason I can see the top even though it's over six feet above the cut plane. I changed another column (a W-shape from the Imperial library) to the custom and the top is not visible. It's cut like it should be.
I should be designing by this point and I'm still as-builting this project.
AutoCAD 2010
AutoCAD 2015
Revit 2015
Solved by constantin.stroescu. Go to Solution.
In Family Editor: Modify > Family Category and Parameters >Family Parameters >Parameter > Show family pre-cut in plan views - uncheck this option > reload the family back into the prokect....you will be able to see now , the correct cut...
Your Name
